Re: the 5025 not stacking well.
I was and still am somewhat concerned about this point. The TI Application Report, Stacking the REF50xx for High-Voltage References which BradC made me aware of says that something that is unexpected happens when the 5010s are configured as two terminal devices AND DRIVEN WITH A HIGHER THAN NORMAL CURRENT LEVEL (3-8 mA as opposed to the spec sheet's value of 800 uA, typical). This configuration as a two terminal device includes connecting the Output pin to the V+ pin, which insures that those two pins are at the same Voltage. The whole point of that application report is that this configuration and current level insures that the device effectively becomes a two terminal, ideal Zener which operates at the rated Voltage of 10 Volts and also at the rated accuracy (0.1% or 0.05%).
The authors of that application report further state that they verified that other members of the REF50xx series also exhibit that behavior. I am not 100% certain that this statement applies to the REF5020 because the TI spec sheet states it requires a higher Voltage margin, but they seem to be saying even that as well as including all the other members of the REF50xx family.
The TI spec sheet states that all members of the REF50xx series need to operate with a supply Voltage (V+) which is at least 200 mV higher than their rated output Voltage except for the REF5020 which requires the same 2.7 V for V+ as the REF5025.
I therefore suspect to be able to confirm that the REF5025s will also exhibit that behavior when configured in that manner and when operated with 3 to 8 mA of current at their ground terminal. I presently intend to confirm this as a first step when I have the needed parts at hand. Then I will add one or two 5010s to that stack and again check the results. I do not expect that a different supply will be needed, only a bench supply that can deliver 12 to 32 Volts at that stage. One step at a time and I will post the results.
If the above checks out, then I will construct a supply that can deliver about 265 to 290 Volts and try a final stack size which will allow Voltages of up to 260 to be produced.
If I am attempting to have a reference chain that goes up to 260 V, I do not see how any reasonable amount of Voltage doubling with a 24V or 2 x 24V = 48V transformer would be of any help. And the application report plainly calls for 3 to 8 mA, not just 2 mA. But I have not used Voltage doubling in any prior power supply designs so I am going to look at it. Wouldn't multiplying the Voltage by six also mean that the transformer(s) also need to supply at least six times that needed 3 mA or 18 mA. And that probably means 20 or 25 mA to be on the safe side.
As for your last paragraph, "The main idea with the stacked reference is that with a good DMM one can measure the individual steps and than add the voltages. So the initial accuracy is not that important. Just for the 0.1 % range it is much easier to use resistors." I am not sure what you are saying.
I am hoping that, by using the 0.05% REF50xx parts, I can achieve individual steps at that, 0.05% accuracy level without any need for verifying with a more accurate DMM or other device. Hence, for me the initial accuracy IS that important. I am hoping to construct a Voltage reference that is more accurate than any meter that I presently own.
And I would like to be able to tap off individual Voltages from that stack at 2.5 V intervals over the entire range from 2.5 V to 260 V. Of course, only one such Voltage would be in use at any given time. Perhaps this is overly ambitious, but I will see.
I am in the process of determining how to economically construct a DC supply between 265 and 300 Volts at present. This seems to be mainly a question of the transformer(s) used. I do not think that a switching supply is a good idea as it would probably introduce the switching noise as an undesired factor. I AM going to look into your Voltage doubling or multiplying suggestion as that could possibly solve the transformer problem. I may even have one that would work.
In any case, thanks for your answer.
The Ref5025 will likely not stack well in the simple configuration. The REF5020 sopposedly needs a minimum of 2.7 V for the supply and this should also apply to the 2.5 V version. So 4x2.5 V are better done with the Ref102 and a divider. REF5025 could still be stacked with a different supply.
Die Supply for the whole chain should be regulated, to get a reasonable stable current. One may get away with a reasonable good constant current source, ideally in a way to also withstand a short.
As the refference chain only needs a low current (e.g. 2 mA) one can us a diodes / capacitor voltage muliplier. So one could get away with a more normal 2x24 V or similar transformer.
