Author Topic: TTF: Ultra tiny micro DC 2 pole connectors  (Read 1922 times)
Online KjeltTopic starter
« on: January 01, 2017, 06:26:07 pm »
Hi all,
Someone asked me to add led lighting to his Lego and other train hobby buildings.
I am using the 0,25mm teflon wire and soldering them directly to smd leds that I glue stuck.
But now I am trying to find very very tiny DC connectors with requirements:
DC 24V
2 pole
100mA
Dimensions around 4mm or smaller.
Wire to wire connectors not to pcb
To be used with the teflon wirewrap wire?
Anyone has a tip? , preferably available through ebay, farnell or tme.
« Last Edit: January 01, 2017, 09:55:22 pm by Kjelt »
Online jpanhalt
Re: TTF: Ultra tiny micro DC 2 pole connectors
« Reply #1 on: January 01, 2017, 06:49:59 pm »
4 mm is not all that small.   Two conductor standard hobby connectors are on 2.54 mm centers, such as these: https://hobbyking.com/en_us/jst-series-connector.html OUtside might be a little over your 4-mm criterion.
JST (and others) make connectors that are 2 mm on center or smaller and are considerably smaller outside dimension.  This one is 3.8 mm outside dimension: http://www.jst-mfg.com/product/pdf/eng/eSFH.pdf
John
« Reply #2 on: January 01, 2017, 09:22:55 pm »
Yes I really would like it to be as small as possible.
Thanks but that eSFH connector is way overkill with 4A and 130VDC  :)
Online jpanhalt
« Reply #3 on: January 01, 2017, 09:41:24 pm »
I was trying to urge you to use the parametric search for your favorite vendor.  As you get smaller and smaller, the difficulty of assembling by hand gets harder.  Here is a partial parametric for you to try:
http://www.digikey.com/products/en/connectors-interconnects/rectangular-connectors-free-hanging-panel-mount/316?k=connectors&k=&pkeyword=connectors&pv89=170&pv89=109&pv89=108&FV=fff40016%2Cfff802f5%2Cffe0013c%2C1600002&mnonly=0&newproducts=0&ColumnSort=0&page=1&quantity=0&ptm=0&fid=0&pageSize=500
Note, some of those connectors are quite small.  0.6 mm is about the limit for me to hand assemble, but there are ones even smaller.
John
« Reply #4 on: January 01, 2017, 09:54:49 pm »
Thanks, I was curious if there were members that also had experience with small model electronics and if they used certain "standard" connectors. It does help me to get the requirements more specific such as that the connectors should be wire to wire and to pcb   :)
