I'd at most be pulling 3.3 watts and can tolerate 4.2v of input voltage to the regulator.
If you are expecting to draw 3.3W (I'm assuming this is on the 3.3V) through an LDO, that translates to
30W on the 30V input, with over 26W wasted in the LDO.
You need to use a buck converter.
