Author Topic: Power circuit without using inductors  (Read 2262 times)
Offline sagnikbasuTopic starter
  • Country: in
« on: February 03, 2017, 07:39:43 am »
Most of the power circuit today use inductors for voltage conversion. Can we design one for negative dc -dc voltage conversion without using any kind of inductors ?
Can charge pump be considered for power circuit applications ?
Offline KhronX
    • Khron's Cave - Electronics Blog
Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
Offline Codebird
Re: Power circuit without using inductors
« Reply #2 on: February 03, 2017, 10:07:49 am »
There are a few ways. You don't see them very often because they are just inferior in most ways to inductors.
Inductors: Compact, efficient, the modern solution in most circumstances.
Capacitor charge pumps: Efficient, but only practical for low current.
And the old-school ways, from before SMPS was practical:
Motor-generator sets: Bulky, noisy, inefficient, unreliable.
Battery switching: Bulky, inefficient, needs frequent servicing.
Vibrator-transformer: The archaic version of the SMPS, and it still uses inductors. Used to be used in a lot of car radios to power valve circuitry.
Electrostatic mechanical with motor drive: Used for generating crazy-high voltages at miniscule current.
Offline David Hess
  • DavidH
« Reply #3 on: February 03, 2017, 09:07:40 pm »
The common alternative is an inverter where the transformer is not used for energy storage; this has the advantage of being lower noise than a switching converter.  Big charge pumps using big capacitors and power transistors are also possible.
Offline Alex Eisenhut
  • Place text here.
« Reply #4 on: February 04, 2017, 01:38:34 am »
Offline jbb
« Reply #5 on: February 04, 2017, 01:39:28 am »
Note also that charge pumps can be less flexible than inductor-based designs.
Normally, a charge pump delivers some rational gain.  Typical examples are 2, -1, 3 etc. (minus some small voltage drops).  This is quite efficient.  You transfer energy from a capacitor with voltage VA into a capacitor with voltage VB, where A is a little more than B.  The average conduction power loss Pond will be related to the average current Iavg.  Pcond = Iavg * (VA-VB).
Hoever, if you really need arbitrary voltage output, it can be done (I think by adjusting duty cycles).  So VA >> VB.  This means Pcond is large, and the converter is less efficient.
If you need to operate in unusual environments (e.g. inside a large magnetic field such as MRI machine), it may be possible to use air-cored inductors.
It is also possible to create multi-level switched capacitor converters which can deliver gains in the form of N / M, where N and M are integers.  This allows for more output voltage levels with adequate efficiency, but requires more complex circuitry.
