Author Topic: Power bank Issues low power Loads issue  (Read 2310 times)
Offline DanielradcliffTopic starter
  • Meow hello I have autism
« on: February 21, 2021, 04:20:44 am »
Power bank. Anyone know of a usb power bank Circuit that does not go to sleep when powering light loads like a small radio or an Arduino
« Last Edit: February 21, 2021, 04:23:34 am by Danielradcliff »
Meow hello I’m DanielRadcliff
Offline SilverSolder
Re: Power bank Issues low power Loads issue
« Reply #1 on: February 21, 2021, 04:50:52 am »
I own an older one that works with low loads...  but I haven't been able to find one like it since.
It seems the newer ones all use the same IC and the people who designed that IC were too clever by half.
The following users thanked this post: Danielradcliff
Offline janoc
« Reply #2 on: February 21, 2021, 11:05:08 am »
That's a good problem to have ... I have a dual output power bank (iGET B-20000) with outputs labeled 2.5A and 2.1A. And I have naively thought - "Yay, good enough for my Raspberry Pi ..." Except RasPi turns off right away.
OK, out comes the electronic load and the bloody thing outputs only 4.3V at 2A of current!  :o
It is anywhere close to 5V only if you stick to the basic 500mA load. I guess those numbers printed on the bank are "won't start smoking within 10 seconds if you stay below this ..." rating. WTF ...
Offline subliti
« Reply #3 on: February 21, 2021, 11:36:18 am »
Idk
But what you could do to prevent this, is to use a small mcu, load resistor and a mosfet and choose a resistor value so that it pulls lets say 100mA. And than u just programm your mcu to give a 1sec pulse every 20sec or so. Depents on the power bank. So if you know ur power bank deactivates 40s after it detects "no" load, than u just pulse it every 35sec.
This would prevent the turning off.
You could then for example build a small adapter board with this circuit with 2 female usb sockets (or one male socket that connects straight to the power bank and the other is female), and than this could be used on any power bank
« Last Edit: February 21, 2021, 11:39:44 am by subliti »
Offline mino-fm
« Reply #4 on: February 21, 2021, 06:25:42 pm »
Please use a translation program http://www.mino-elektronik.de/Powerbank/powerbank.htm
No!
« Reply #5 on: February 21, 2021, 10:33:17 pm »
Is there a ready made solution
« Reply #6 on: February 21, 2021, 10:47:18 pm »
No!
Well, they all behave the same...   every single one I've tried for the last several years have refused to cooperate with small loads.
Are you aware of any that act differently?  I'll be the first to buy!
Offline Peabody
« Reply #8 on: February 21, 2021, 11:07:54 pm »
Here's one you might look at:
https://www.amazon.com/Voltaic-Systems-Formerly-Battery-Samsung/dp/B07ZS3WYZY/ref=sr_1_1?dchild=1&keywords=voltaic&qid=1613947993&sr=8-1
ALWAYS ON FEATURE - Voltaic's upgraded "Always On" feature makes it easy and efficient to use with various sensor or time lapse applications
Looks like the Sales department has caught up with the needs of the market!   Thanks for the pointer, I'll have a hunt around again now that it appears to be an "upgrade" to go back to how they always used to work!  :D
Offline Peabody
« Reply #9 on: February 22, 2021, 05:00:57 am »
At considerably lower cost, there is something called the "18650 battery shield v3" which has the battery holder, a charger, three ganged 3.3V linear regulators, and a 5V boost converter with USB-A output.
https://www.ebay.com/itm/18650-Battery-Shield-Micro-USB-Wemos-ESP32-V3-ESP-32-for-Arduino-Raspberry-Pi/293951798138
These can be found lots of places - Ebay, Aliexpress, Amazon, Banggood.  They also come in 2-cell and 4-cell versions, but I think only the single-cell v3 behaves correctly as an always-on UPS.  Andreas Spiess has a video on it:
But there's a potential problem with getting charging to terminate properly if you are powering the load while charging:
However, if your circuit periodically goes to sleep, that may enough to get charging to terminate.
Offline oPossum
« Reply #10 on: February 22, 2021, 05:53:47 am »
« Reply #11 on: February 22, 2021, 08:10:57 pm »
Thanks everyone but I still don’t have a solution that I can make that will fit space is tight or to buy  to solve this issue keep trying everyone I’m listening
« Last Edit: February 22, 2021, 11:59:51 pm by Danielradcliff »
Offline Peabody
« Reply #12 on: February 22, 2021, 10:57:35 pm »
Well, in theory you could have an 8-pin ATTiny processor, a decoupling capacitor, a transistor, a base resistor and a load resistor.   Might not need the base resistor if the GPIO pullup resistor is enough to drive the transistor, which it almost certainly would be.  Might not need  the capacitor either.
« Reply #13 on: February 22, 2021, 11:39:54 pm »
Thanks everyone but I still don’t have a solution that I can make that will fit space is tight or buy  to solve this issue keep trying everyone I’m listening
How tight is the space?
Online NiHaoMike
    • Facebook Page
« Reply #14 on: February 22, 2021, 11:46:13 pm »
How about just get a boost converter module that doesn't automatically turn off?
« Reply #15 on: February 23, 2021, 12:06:14 am »
Seven 3/8 inches  deep   by 5 5/8 wide  12 Inches tall These measurements are all in inches
« Last Edit: February 23, 2021, 12:09:36 am by Danielradcliff »
« Reply #16 on: February 23, 2021, 12:16:53 am »
The inside The center thing is the usb power bank Circuit from Amazon up above is the battery holders for 18 650 cells  to the left is a step down converter for the solar panels to take in the 7 V and drop it to 5 V for the Power bank circuit which is one of the issues  there’s another issue With the power bank it’s self powering low load device.
The thing below the power back circuit is a usb plug thing for the back .
« Last Edit: February 23, 2021, 12:27:44 am by Danielradcliff »
« Reply #17 on: February 23, 2021, 02:30:31 am »
Have you made a circuit diagram / sketch of how the system you are building is meant to work?
« Reply #18 on: February 23, 2021, 03:23:14 am »
No I have not made a sketch it’s all in my head currently I’m trying to produce a schematic for you all I’m using an app called iCircuit. Use your imagination on this Schematic picture  Are used by components I had available in the app I’ve never made a schematic in my life actually So this is kind a hard i’m good at taking in information but not putting out information it’s complicated
« Last Edit: February 23, 2021, 03:35:29 am by Danielradcliff »
« Reply #19 on: February 23, 2021, 03:44:05 am »
More schematic pictures
« Reply #20 on: February 23, 2021, 06:32:11 am »
Keep working on it, it is beginning to make sense!
