Hi everyone,
Here's the situation. I'm working on a CCM PFC stage, currently using an RM10-size ferrite core inductor. There is a stringent line harmonics requirement that we are trying to meet, which drove the decision to use CCM in the first place. Transition-mode (TM) is much more typical in this power range (~120W), for a "normal" application.
The efficiency is pretty good, and actually very much optimized at this point. I went through the whole switching loss vs Rds-on optimization thing, and we've tried many different MOSFETs to try to find the sweet spot.
But, I'd really like to get another 1% efficiency, if possible.
I've seen many commercial power supplies with CCM PFC stages use a Sendust or moly-permalloy (MPP) core, instead of ferrite. These converters can typically get away with a lower switching frequency, which gives way to lower switching loss. With a high enough magnetic field intensity (current through the inductor), the permeability begins to roll off, but gradually, unlike ferrite. Depending on the load, the permeability of these cores can "swing" from high to low, and back to high again, during one 60Hz mains cycle. This can be advantageous for CCM converters, but I still can't exactly wrap my head around why!?
I've seen several references to swinging inductors in CCM PFC controller application notes, but never a detailed design procedure, or at least a solid explanation of the theory surrounding them.
Here's one app note, for example:
https://www.infineon.com/dgdl/Infineon-ApplicationNote_PFCCCMBoostConverterDesignGuide-AN-v02_00-EN.pdf?fileId=5546d4624a56eed8014a62c75a923b05Can anyone point me to any good resources on swinging inductors for this application?
Thanks!
