Boost is simple and alright, the limitation of the simplest design being that it "leaks" the 28VDC input directly through the diode even if it's turned "off", and hence cannot provide short circuit protection; unless you add an extra protected switch.
If this doesn't matter, I'm sure boost will be the smallest and cheapest. I think your spec can be achieved in about 15x15mm area quite easily.
