Author Topic: Ferrites in power supply good or bad? How to reduce noise on VCC?  (Read 26974 times)
Offline jmajaTopic starter
Re: Ferrites in power supply good or bad? How to reduce noise on VCC?
« Reply #25 on: November 01, 2013, 10:47:03 am »
There is no isolation in this system and the noise clearly comes from the RS422 transmitter in the same system.
« Reply #26 on: November 01, 2013, 12:57:06 pm »
No I removed the shortcut from the ferrite between the 5V line and the 5V LDO output (feedback is still from the 5V line). I then remeausered the noise pulses. The 3.3V line on both sides of it's ferrite were not changed at all and only a very minor change at the 5V line. But at the 5V LDO output side of the ferrite there is a very clear change. The p-p dropped from ~30 mV to 9 mV. Pictures attached so the same as before + the other one showing LDO output pin in yellow. With a multimeter I can get more noise at the 5V line (~4 mV RMS) after this modification and it is showing only 200 uV RMS at the LDO output.
Actually this is the same thing I noticed in the very beginning, that the LDO output is quieter than the 5V line after the ferrite, which was put there to make things reversed.
There is no capasitance between at the LDO ouput, only on after the ferrite. So I can only imagine, that 5V LDO is not making any part of this noise, it all comes through the 3.3V LDO. So I'm guessing, that connectig 3.3 LDO to the other side of the 5V LDO (5.6 V line) would eliminate all the noise on the 5V line. Also maybe getting 5V line directly from the 5V LDO output and 3.3V LDO input through ferrite might work quite well.
Those are a bit more difficult ro rework on the PCB I have, thus I don't know yet will I test them or not. After all I don't really have a noise problem anymore, this is just trying to learn something.
« Reply #27 on: November 01, 2013, 02:21:50 pm »
I did the next change anyway. Now I get 3.3V LDO input from the same spot as 5V LDO intput, thus from the buck output after a ferrite. But the modification moved also 2x4.7uF caps away from the 5V line to the LDO inputs. So now there is no cap near the 5V LDO output, but there still is a few 100nF (closest one ~2 cm away) and one 4.7 uF (~5 cm away).
The result is promising. No change at the RS422 side of the 3.3V line ferrite. A bit lower p-p on the 3.3V line and no sign of RS422 traffic on the 5V line, which now has 20 uV RMS while transmitting RS422. And I get even a bit less noise on from the sensors
But there is some new noise visible at the 5V line. Maybe due to lack of cap?
« Reply #28 on: November 01, 2013, 03:04:59 pm »
Now I even added one 4.7uF cap to 5V. Multimeter shows 0.00 mV RMS and I get no p-p noise from ADC while reading 15 bits inputs shortcut, thus I guess RMS noise level is at 18 bits or below.
Here is updated pictute. Note that I changed scale at 5V measurement 10mV->5mV.
The following users thanked this post: Manx
