Hi Bob, you show two scope plots - can you elaborate on the circuit configurations used for each plot, and the test conditions? If that is the noise floor of each configuration, it may be more meaningful to show performance as a frequency spectrum plot (maybe your scope has that capability or you have a soundcard and software set up to do it).
Is it the noise floor that is the concern, or did you think the Aceinna sensor would achieve a wider bandwidth, or better insulation, or DC accuracy ...?
Ciao, Tim
