hey
by shorting across the 200ohm resistor , I can get down to zero ( or anywere els below 9mA/90mA )
ther's somthing wrong with shorting it ?
BTW : I trent 24houres with current set to~ 902mA , here's pic of that trend -->
the whole sistem runs at +-1% (resistor's fault )
another wierd thing is . when no DUT is connected , the set current reads lower by 13-15mV , when does connected , reads out by +-1% (fine )
does the curve represent relativly stable loop ? or thats not good ?
thank you in advance !
