...Finished a transformer, of course. Should be good for a few amperes, eh?
Construction is three series sections of ~15 turns each (10AWG litz, primary), three parallel sections of 2 turns (sheet, secondary). Output terminal is parallel plates. Insulator is fish paper.
I just barely managed to solder the secondary winding straps onto the plates, with my hot air machine turned up all the way plus using my soldering iron for local heating. Took a good ten minutes of heating, plus fiberglass blanket draped over the assembly to hold the heat in.
The top plate has a wishbone or spanner shape to it, picking up the three outer secondary connections but not extending under the core. The bottom plate picks up the inner secondary connections, and has a smaller hexagonal hole in it to mate with the straps (again, soft soldered).
Earlier view of the primary, and the driving circuitry -- a control board featuring phase, current and power regulation for the resonant load, as well as fault latching and rudimentary remote control (on/off, fault and power set/read); and a half-bridge inverter board good for a kilowatt or so.
It's been a long time since I did much work on this induction heater project. Last time I did this much work, was probably back in 2009 when I built this thing:
which I ran up to 5kW at the time, though with some quirks that needed a bit more tinkering to finish up, but it was definitely proof of concept. But then I had to move out to college. And after that, I started working, and after THAT, I didn't have a workshop or a 240V outlet, and...
I've still got that unit; I'm finally getting around to... rearranging, or repurposing, but not necessarily scrapping it? Here's the output network removed, fitted with a shiny new coil:
Not nearly as pretty as it was back then! Well, the old transformer doesn't do me much good. I did wire it up to the new inverter, and see that everything still works; got some steel rod nice and red-hot, but it's neither the right turns ratio nor low enough stray inductance (looks to be close to 0.8uH in the pipes between capacitor, transformer and coil terminals; what was I thinking?!
) to do what I want to do now.
Which is why I made the new transformer, should be very low stray inductance indeed. I'm aiming for a tuning range of 0.2-2uH and Q = 5-50, a very practical range for smaller coils useful at these lower power levels, for applications like brazing and heat treating of small parts.
