Author Topic: Coil gun  (Read 3509 times)
Offline House91320Topic starter
Coil gun
« on: November 25, 2010, 03:09:27 am »
i am going through the proses of rebuilding my coil gun an would like to make i portable would i be possible to use a pwm signal instead of AC.
Offline Simon
  • Global Moderator
    • Simon's Electronics
Re: Coil gun
« Reply #1 on: November 25, 2010, 06:44:42 am »
you will need you PWM signal to be fed via a Hbridge as it has to be dual polarity for the voltage multiplier to work
Re: Coil gun
« Reply #2 on: November 25, 2010, 04:30:25 pm »
Ya that is what i was thinking of doing i just wanted to check that.
Offline Simon
  • Global Moderator
Re: Coil gun
« Reply #3 on: November 25, 2010, 06:54:19 pm »
but it needs to be 50% anyhow
Online Zero999
  • 0999
Re: Coil gun
« Reply #4 on: November 25, 2010, 09:49:08 pm »
You don't need an h-bridge, a half bridge will do.
What voltage do you need? Using a flyback transformer is normally the best way to go.
Offline Time
Re: Coil gun
« Reply #5 on: November 26, 2010, 01:17:42 am »
I'd be interested in see the total design.  I have a coil gun project as well.  I'd be interested in seeing your coil geometry and your efficiency.
-Time
Re: Coil gun
« Reply #6 on: November 26, 2010, 09:04:35 am »
I need aprox 400 to get the full 1.7kj of power
