I'm designing a modular prototyping system consisting of daisy-chained PCBs connected edge-to-edge. The PCBs will be roughly the size of a bookmark (2 x 5 cm) and connected so their long ends butt together (e.g., 3 connected boards would measure 6 x 5 cm).
Does anyone have any alternative suggestions? Thanks!
I would separate the mechanical and electrical aspects, as EPAIII posted.
Since it is for prototyping, and not production, one approach I want to try for myself, in a future project:
* make base plates (thin metal sheet) of various lengths, that accommodate 2, 3, 4, ... boards;
* have room on each board to screw it into a base plate, using screws (thumb screws in your case), and short spacers for insulation;
* on the base plate, form threaded mounting points for the boards:
* use a punch to draw extruded holes in the base sheet, then roll threads in the extrusions using duo-taptite fasteners
https://taptite.com/assets/files/duo-taptite.pdfYour boards are small. So this would be a cheap design with good mechanical stability. The extruded holes themselves will help stiffen
the base plate.
I have scavenged some 2.5 mm dia. steel rods from old CD-ROM and floppy disk drives, to try as punches, for this future project of mine
I'm hoping to use them with M3 taptite fasteners.
