I'm assembling a new PCB. On this PCB is an 0805 green LED. One pin goes nowhere (because the series resistor is yet to be fitted).
If I put either LED pin in good contact with my hand, then touch the direct-mains soldering iron tip to the other contact there is a very brief flicker of dim light.
The flicker only recurs if I remove the iron, then re-apply it. If I unplug the iron, nothing happens.
I can only think of obvious things like mains earth not same potential as my hand, and I'm looking at tiny ESD events generated by my clothing? I can see the LED would rectify any AC and hence the effect is observed 'either way'. However, I'd think ESD would be unipolar, with polarity dependent upon the actual composition of the clothing I'm wearing. I have in mind those electrostatic experiments where a glass rod is rubbed with different materials and the result is either a net deficit or excess of electrons.
