Author Topic: Jumper for 125MHz  (Read 892 times)
Offline luky315Topic starter
  • Country: at
Jumper for 125MHz
« on: November 23, 2023, 08:42:30 pm »
I need something to manually select between 2 clocks, one of them is 50MHz and the other one 125MHz. I have never used a classic 3 Pin header with a jumper for this frequency range, but I am expecting problems. So what would be a simple, mechanical alternative which performs better?
Offline tooki
Re: Jumper for 125MHz
« Reply #1 on: November 23, 2023, 09:08:37 pm »
I doubt it’ll be a problem, 125MHz isn’t all that fast.
Alternatives/variations:
-headers and jumpers smaller than 2.54mm pitch
-small SMD DIP switch
-small SMD SPDT slide switch
-solder jumper
-simple circuit using jumpers to control some logic gates to select the clock electrically
Offline PCB.Wiz
« Reply #2 on: November 23, 2023, 09:09:07 pm »
Why do you expect a 3 pin header to be a problem ? It's not 125GHz.
You could always pay a little bit more, and go for a 2mm jumper, which has a smaller footprint. You can even buy 1.27mm shunts/jumpers.
Offline moffy
« Reply #3 on: November 24, 2023, 11:09:37 pm »
If using a jumper, which should be fine, you might want to surround the header with ground plane, to reduce emissions. The 125MHz is not that high but the edges are pretty fast if we are talking square wave/logic signals.
Online SiliconWizard
« Reply #4 on: November 24, 2023, 11:18:35 pm »
It shouldn't be a problem unless the jumper itself is really loose.
One problem I see with that though, if you're using TH jumpers, is the antenna effect of the pin header. Outputting a clock on a pin header can ruin EMC. Done and tested.
So I would favor a solder jumper.
Offline Terry Bites
« Reply #5 on: November 26, 2023, 02:20:39 pm »
CK make a nice little switch TDD01H0SB1R, will you feel the benefit. Probalby not.
