I am designing a high density PCB (to the point of using 0402) and will also be designing and building a DIY test fixture (
don't yet know the mechanical architecture yet - any suggestions also welcome!!) for it to use during development and also initial production testing and programming.
I am wondering about the following (any suggestions/tips) considering the test fixture will be DIY:
- smallest test pads size that still allows to use not too expensive probes
- preferred grid spacing to allow a relatively decent density while also make it not too difficult to assemble by hand (never done it before)
- any suggestions on the probes types (round tip, cone tip, different bodies perhaps) and a preferred or common brand/UK-distributor
Thank you
