Power factor with choke input can be in the 0.8-0.9 range, IIRC. Better than cap-input, but still less than full. This is easy to see because current flows through the transformer even when voltage is low, whereas at PF=1 current is proportional to voltage.
A resonant or semi-resonant filter can do better, but DC regulation is much poorer. Passive PF tends to be harmonic filtering, producing a compromise between acceptable regulation, and filtering the strongest harmonics (lowest, 3rd and 5th most importantly, etc.).
