Hello!
I just designed a board that will be hooked up to a very heavily modified laptop and will provide three external PCIe connectors. Basically, it's only an adapter board with barely any active components.
![](https://0805.pl/uploads/pcie-adapter-board-1.png)
And I have three main concerns regarding it:
- did I use too much of ground stitching vias? Is there anything to worry about regarding that?
- it's a 4-layer board, the layer stackup starting from the top is as follows:
1: signal traces and ground pour
2: ground plane, no signal traces
3: 12V power plane, no signal traces
4: signal traces and ground pour
I plan to install a high-end GPU in the PCIe x16 slot, the GPU can pull up to 75 W of power from the slot and probably generate some minor switching noise from the DC-DC switching regulators that it has, should I be worried about the PCIe traces running on the bottom layer (right next to the 12V power plane) getting some interference from that?
https://0805.pl/uploads/pcie-adapter-board-2.png - Is this an optimal distance of ground pour to signal traces? Does it matter much? I also noticed that on some commercial designs they don't always make ground pours on exposed layers if there are internal ground plane(s), maybe I also should have only the internal ground plane?
Huge thanks for any advice!
