As i'm sure oyu all know, right now the supply of any component that is in anyway even slightly specalist, and lots of parts that are not even specalist at all, is very, very constrained!
I'm trying to design out some digital isolators from a design to enable us to make that product
Now, those isolators are not actually needed for their galvanic isolation as such, because the boundary across which the signals go is not, broadly speaking at two different ground potentials. However, the isolators we use to limit the coupling between the two sides for EMC reasons, because the power supplies of each side are heavily filtered etc. We had tried std optocouplers in this position, but due to the extreme temperatrue range of the product, and ageing effects on speed and DTC etc, these were replaced with the now-impossible-to-get isolators.
After doing a bit of simulation and head scratching it looks like i can maintain enough EMC performance without galvanic isolation by moving to differential signalling. ie LVDS. But same problem, i can't guarantee LVDS drivers are available without enormous lead times etc.
So, question.
Given that my data rate is really pretty slow, lets say up to 200kbs or so as a max, can i replace the digital isolators with a home-brew differential signalling type arrangement, using jelly bean logic and analogue parts?
The driver seems relatively easy, any comparitor or buffer with complimentary outputs can do some sort of psuedo differential or anti-phase type current loop output using fixed resistors.
The diy reciever seems trickier to me however? As the common mode ground offset could be 1Vpkpk dynamically, although the DC offset should be much lower, in the order of a few hundred mV
If i centred the dif output at half supply, lets say 2.5v, then the reciever needs to account for this surely?
I bet there are some nice tricks here i am missing
It's hardly a new thing in electronics after all.
Any advice welcomed!
