Author Topic: PCB Project - Jellybean boards design  (Read 1279 times)
Offline glentekTopic starter
« on: June 15, 2020, 12:15:08 am »
Given the low cost of boards from such as JLCPCB, I decided to design some jellybean boards. Simple functional circuits like voltage amplifiers, comparator, power supplies etc. Have a look at my schematic and see what you think. I have space for one more board. Most are about 30 x 18, some a bit bigger. The design is one file, boards can be cut apart with a hacksaw. Not going for routing or v groove to save cost.
The following users thanked this post: nuclearcat
Online MarkF
Re: PCB Project - Jellybean boards design
« Reply #1 on: June 15, 2020, 04:30:43 am »
Your PCB house is going to see that as eight different designs and charge accordingly.
You will want to break each one into its own PCB and then panelize it.
Offline spudboy488
« Reply #2 on: June 15, 2020, 11:56:04 am »
This is something I've always wondered about. Unless you were submitting multiple gerbers and asking the board house to panelize them, why would they care about how many designs are on a single gerber set. OP will even be doing their own cutting so the board house doesn't have to do anything extra.
Online sleemanj
  • Professional tightwad.
« Reply #3 on: June 15, 2020, 01:52:26 pm »
Money principally I expect, or rather less of it.  They make money on volume with these crazy low prices, an individual order makes them pennies - allowing phoney-panels like that serves only to reduce volume (or conversely, not allowing increases volume)
Offline Dave
  • Country: si
  • I like to measure things.
« Reply #4 on: June 15, 2020, 01:59:11 pm »
JLC don't seem to mind it (3rd paragraph on the page). Other fabs might, so it's best to read the FAQs before ordering.
<fellbuendel> it's arduino, you're not supposed to know anything about what you're doing
<fellbuendel> if you knew, you wouldn't be using it
« Reply #5 on: June 16, 2020, 01:17:43 am »
I've done this a number of times with JLCPCB and not had a problem. The component references are not repeated - which doesn't bother me.
