Author Topic: How to Fix Broken IC Pin  (Read 25396 times)
Offline bostonmanTopic starter
Re: How to Fix Broken IC Pin
« Reply #25 on: November 15, 2021, 02:30:44 am »
BTW, if you are concerned that you might forget and try to pull it out at a later date, just past a note with a warning sign on the surface. Anything that will draw your attention.
I already plan to take that route. :)
Most likely the dual sockets will trigger a warning sign, but, in any case, this could be less of an issue if the socket pins weren't so cheap. They bend so easy and I sense removing a few times will result in damage.
