Author Topic: PCB Layers  (Read 2864 times)
Offline ChrisGreece52Topic starter
  • Electronics Engineer - Hacker - Nerd
PCB Layers
« on: February 03, 2013, 10:59:41 pm »
I searched for ordering a PCB and i found out that i need to input a layer number...
What does the layer number means at PCB's?
Online Psi
Re: PCB Layers
« Reply #1 on: February 04, 2013, 01:24:59 am »
My guess would be that it's the number of copper layers on the PCB,  2, 4 etc...
Re: PCB Layers
« Reply #2 on: February 04, 2013, 06:13:33 am »
Ok but what the layers do to a PCB (thicker traces and stuff i mean)??
Offline nanofrog
Re: PCB Layers
« Reply #3 on: February 04, 2013, 08:59:01 am »
I think you're referring to the copper weight, which is what determines the trace thickness.
Offline psycho0815
    • H-REG Blog
Re: PCB Layers
« Reply #4 on: February 04, 2013, 09:01:54 am »
Basically you can picture layer like storeys in a house.
If you put your traces on different layers, they can cross each others path without making a connection.
If you want a connection between traces (or planes) on different layers you need a plated hole in the pcb usually a via or component hole.
That way you can pack your board very tightly with components and traces. It is hoewever considered good practice to keep your layercount as low as possible.
2 layers is pretty much standard these days for hobbyprojects and the like.
Everything above 4 can get expensive rather quickly..
If you like, check out my blog (german):
http://h-reg.blogspot.de
Offline poorchava
  • Troll Cave Electronics!
Re: PCB Layers
« Reply #5 on: February 04, 2013, 10:11:01 am »
Actually even 4 layer boards are very expensive for low quantity. First example would be itead-tyle chinese services. 1pcs of 5x5 2 layer costs $10 and the same for 4 layers costs $65. I think this is because you can fabricate 2 layer pcb out of premade double-side copper clad laminate while for 4 layer pcb you need quite difficult lamination process to fuse the layers together.
Re: PCB Layers
« Reply #6 on: February 04, 2013, 12:42:42 pm »
Got it thank you :)  :-+
