@Sparkydog,
Call me biased by too long in the service trade!
Axial glass fuses are cheap and nasty for mains use. However *any* repair workshop can be expected to have a good selection of plain 20mm glass fuses, and the push-on axial end caps I suggested, although supposed to be use once can be reused several times. We used to stock both fuses (in fast, slow blow and some values of ceramic HRC), and axial end caps.
The various styles of radial fuse are generally much much nicer, and typically are immune to the rupturing problem I noted at typical domestic mains receptacle peak short circuits, but good luck having the correct one in stock for a repair. Sometimes we were able to match up the radial fuse to one we did stock, but often the markings left us guessing about its characteristic, or what we had was a different pin spacing, so we were stuck with closing up the item to get it off the bench, and waiting for a parts order. Spend enough time closing stuff up only to have to strip it down again next week, and you too will develop an irrational dislike for the part causing the delays!
