Author Topic: Part identification - high voltage SMD ceramic thick film resistor  (Read 1248 times)
Offline r0d3z1Topic starter
Can anybody help to identify this component ?
It looks like an high voltage SMD ceramic thick film resistor. The left pin are connected to the DC-link and from the 6 pin on the right start 6 tracks directed to the microcontroller.
Thanks
Offline Gyro
Re: Part identification - high voltage SMD ceramic thick film resistor
« Reply #1 on: April 10, 2019, 10:06:36 am »
Strange (from your connection description). It looks more like a current shunt, with the current pins on the right, shared over multiple pins, and the potential sense pins on the left.
Best Regards, Chris
The following users thanked this post: r0d3z1
Online T3sl4co1l
    • Seven Transistor Labs
« Reply #2 on: April 10, 2019, 10:18:20 pm »
Alternately, it looks like not much ratio, e.g., about 15 squares of resistance on the long arms, and one square in the middle.  So, a differential gain of 1/15 to 1/30, depending on exactly how the fields work out.
That assumes the conductive traces are solid underneath the enamel, and not snaking further.
I can say say with confidence, you aren't going to find this unless it's specifically made available by the manufacturer as a replacement part.  Consider replacing the board.
Seven Transistor Labs, LLC
« Reply #3 on: April 12, 2019, 11:56:17 am »
Initially I have also thought the same, however the connection doesn't make sense for a shunt.
Thank you Tim, however the post is not for a repair/replacement purpose. I was curious to understand what this component could be. If it is not a shunt, what could it be ?
« Last Edit: April 12, 2019, 12:00:07 pm by r0d3z1 »
Online T3sl4co1l
« Reply #4 on: April 12, 2019, 01:27:10 pm »
Well then... measure it and see what it is.  It's a four way resistor.  Low values suggest current shunt, high values suggest voltage sense. ;D
Otherwise, no, I don't have any particular insight into why it's drawn the way it is.  Who knows...
