Hi everyone,
I'm designing a DALI lighting control interface to bridge between my wireless home automation system and standard DALI devices. The DALI system works by using a single pair of wires for both power and signalling, a PSU on the DALI bus provides a 16V DC supply with no defined polarity and a 250mA current limit, devices communicate with each other by short circuiting this bus, using a manchester encoded serial protocol.
Although the DALI bus operates at 16V (actually 16V +/- 6.5V), it doesn't have to be isolated from the 240V mains supply and the DALI control wires are run in the same cables as the 240V mains supply. As a result it's not unlikely that my bridge device could be accidentally mis-wired and connected to 240V mains power. I'd like it to survive this, ideally with no user intervention to fix it afterwards, other than correcting the wiring.
To this end, I've come up with the over voltage protection circuit on the far left of the attached schematic.
Does this look like it would work?
The theory is that the main circuit starts in a turned-off state due to Q1 being off. Then R1 slowly charges C3 so that in normal operation when connected to a 16V supply, Q1 will pass its gate threshold voltage after 300uS.
However, if it's connected to 240V then it will take R1 and C3 16uS to pass Q1's gate threshold voltage, but the SCR T3 should trigger within 1uS and prevent Q1's gate ever passing the threshold and turning on.
I've also added a 33V zener diode and a fuse in case the main protection fails for some reason, but I suspect this is probably pointless and that the zener would explode instantly if subjected to 240V and many amps.
Thanks
