Hi. I've used veroboard pins on a veroboard so I can connect flying leads or jumper wires. I went and ordered some breadboard jumper wires with female sockets on the end, but they do not fit the 1mm diameter veroboard pins. So, I need some jumper leads with female sockets that fit the 1mm diameter pins.
Is anyone here buying such a product, or identified a supplier? I've not turned up anything so far. Thanks.
