So recently my 40 watt weller broke down, and I went to RS and bought a 15/30W Iron. The RS Iron is HORRIBLE, at 30ws it burns up tips and at 15w it does not retain enough reserve heat to be useful, and I use small .032 60/40 solder. I really liked my 40 watt weller but I would like something a bit better and I don't have a whole lot of money. What I do have is enough for an Iron and all the parts I need to make my own station. I feel like I have two options:
The first would be to purchase another solid 40 watt weller, or Hakko 508. Basically any decent quality standard iron will do. Then I could just ass a light dimmer to it like most everyone else to get heat control. If I went this route there are two things I'm a bit hazy on. First off I do not want to buy an a dimmer at the hardware store with a big ugly knob! I looked around on digi key at pots and couldn't find any that seemed suitable. If I have a 40 watt iron I would need at the least a 40 watt pott, probably a bit bigger correct? Secondly if I wanted to use a micro to read the pots position to display a percentage would I use an opto-coupler for that?
My second option is to build a fully digital station with a current feed back loop, that way I can solder at 15w and not have to worry about heat loss, this is the better option in my opinion. It does not seem all that hard actually! Maxim maks a great chip the MAX31855,
http://www.maximintegrated.com/datasheet/index.mvp/id/7273 it basically takes care of all the tempature readings for you so all you have to do is raise the power. The two questions I have on this method is how exactly would you digitally control the current on the mains. Secondly Would any iron with a 5 pin plug for a solder station be about the same as far as the sensors inside? I have found these irons with the thermo couples built in for as low as 12 bucks, Im fine with a cheap one as long as I can throw a nice hakko or weller tip in it. Since I am building the station my self I can buy a much nicer "pencil" when I have money as long as it feeds the same data to my station as the cheap one. I found this hakko 907 compatible iro for 8 bucks
http://compare.ebay.com/like/390562392942?var=lv<yp=AllFixedPriceItemTypes&var=sbar
