The TI SN6505 is a pretty nice chip for applications like that, the push-pull config makes for a reasonably low noise output, if you need it regulated, then put an LDO at the output.
If you want it super low noise, add some more filtering before an LDO - I wouldn't recommend relying on an LDO to eliminate switching noise, their rejection at that kind of frequency is generally pretty poor.
