While the voltage reference is still preaged with extended load for another few days until 300h have passed and in most places of germany christian people celebrate "happy cadaver" and the none christian people have a free day too, I decided to do something 'bit off topic to this theme. I started to build myself a small temperature chamber, because our climate chambers at work are in use for the next weeks. Well, no problem at all.
I found all the required parts for that in my home lab, a Styropor box with inner dimensions of 270x165x160mm³ and 30mm wall thickness, a heatsink with a size of 150x150mm², a CPU cooler with fan, a Peltier element with size 40x40mm² 12V/30W, a heater foil and a fitting sheet aluminium, two laser cut D-Sub panels and several D-Sub connectors.
All that is still missing are a few mechanical components, that will be finished by the end of the week.
A solution to read out two SHT25, less then half the price of a SHT75 and somewhat more accurate, via VCOM with additional 3x16 LCD display is currently in progress and will complete the setup.
One SHT25 is to track the chambers temperature, the second one is for the device under test, e.g. the NTC of the ADC board inside its case to calibrate it.
It would have been deluxe if the temperature is controlled via a µC or something similar, but as such controllers are very expensive I will start using one of my lab power supply and set the temperature by manuelly adjust the current on the PSU.
I've also drawn the panels for the Hammond cases and will post them here soon in DXF format. I used the free front panel designer by Schaeffer AG for that purpose. Pictures will follow when finished.
