I dont understand your post tim ?
IGBT's run fine in linear mode, in a feedback system like i have made.
and i tested my product to 1kV input, that is 20% under their max specified voltage,
and i tested isolation to chassis to 2kV so i know it is safe,
It's a technical point, mildly subtle. The difference between tossing stuff together, and proper engineering.
Question: show where in the datasheet you are recommended to operate in this manner.
Feedback is irrelevant; that's more or less implied by "linear mode". Anyway, what's done externally, has no effect on internal current sharing within the die itself.
Can you get away with it? Maybe. If they don't give an SOA at all, who knows, maybe it's full DC with no 2nd or 3rd breakdown? Or maybe it blows up not long after the 10µs short-circuit rating.
The point is, you don't know. It's not a "you idiot, that will guaranteed never work" complaint, it's an information complaint.
(The worst part about this type of argument is, when the person does get away with it, they gain a smug sense of success, not realizing in what sense they have nonetheless failed in the design process, despite apparently succeeding in the build. Meanwhile, the expert looks like a bit of an asshole to everyone, except to other experts who understand the argument being made.)
At best, you need to do a full SOA evaluation (at least including the area you intend to operate in, and somewhat beyond) to see if they're usable at all. (22mA means nothing -- you have a 1kV 1A source to properly test this, right?) And re-test periodically, as the chip design may change over time, or the design moves between different factories, etc. (The latter only relevant to a production context, of course.)
There are some very good reasons why not to use IGBTs. General, not specific, mind: an individual design can be tweaked to respond differently. But it remains true that Vge(th) has a negative tempco, and that IGBTs have the highest power density among Si devices. The active die area is
minuscule.
It's fairly rare to find SOA curves on them, at all; most of them you'll find, are (or were*) very severe in deratings, for exactly these reasons.
Let alone spookier phenomena, like parasitic latchup. But that's been largely solved for decades, I think IGBTs since the (late?) 80s have always addressed that. You still see lots of books/appnotes repeating that...
*I have seen newer, SuperJunction type IGBTs, not only with SOA curves shown, but the full DC curve at that. And it's not like they're doing internal ballasting (extra (distributed) emitter resistance), Vce(sat) is still attractively low. I haven't read anything explaining this remarkable property. SJ MOSFETs benefit similarly, it seems; I don't think I've seen one that doesn't offer full DC SOA. But again, IGBTs operate on a completely different mechanism, and there's no reason to suspect this behavior would carry over to them.
For the record, IRG4PH20K is not this type; a contemporary MOSFET of similar rating would have significant 2nd breakdown limitations.
