Video time!
https://www.youtube.com/shorts/8GnpiZxX6PIIt's only 33 seconds long though so blink and you'll miss it.
This is part of the early debugging process. I'm still working out the timings needed and light thresholds I can get away with. Changing one changes all the others, so it's a combinatorics nightmare!
In the video you'll see the ring make 3 full rotations. Firstly, it does a very fast seek to locate the magnet (ends up at 12 o'clock position). Second, it does a rotation to write a sequence of date bits to the ring.
Then lastly, it just runs around the ring again doing nothing, which demonstrates that the phosphor can store a visible amount of light for at least 1 full revolution without being refreshed. Assuming I can get the threshold right.
This thing is going to be hard to tune for long periods of data retention.
This video wasn't made in a dark room though, so the real contrast and noise will be better in later tests when I've had time to set up a darkened work area.
Encouraging, I think?
Also, there is now a new problem! Notice how that group of 3 bits is noticeably brighter than the rest? That's due to light bleeding across between adjacent bits. Inter-bit noise if you like. I can mitigate this a bit by pushing the emitter tube further through the hole in the plywood so it almost grazes the back of the ring gear. That's about all I can do though.
So plenty of limitations to play with!
