Author Topic: Seeed's Open Parts Library (OPL)  (Read 3209 times)
Online hamster_nzTopic starter
« on: May 19, 2014, 12:59:10 am »
On my doorstep today was my "Open Parts Library v2" from Seeed Studio (http://www.seeedstudio.com/depot/Open-Parts-LibraryBasic-V2-p-1560.html). It is a set of common SMD parts, and there is a matching Eagle library to go with them. Resistors, Caps, a few inductors, fuses,  actives, connectors....
Now that it is in front of me I'm really quite impressed,  superbly packaged, well over a 1000 little bits to play with for my next design. Far better than my shoebox with little bags and partial reels that I currently have.
Even if it saves me a respin of a PCB due to a device footprint missmatch it will be well worth it...
Offline Dago
    • Electronics blog about whatever I happen to build!
Re: Seeed's Open Parts Library (OPL)
« Reply #1 on: May 19, 2014, 06:17:20 am »
In my opinion the best way to avoid this is to make all footprints yourself so if something goes wrong you only have yourself to blame... I personally use PCB library expert http://www.pcblibraries.com/FPX/ which outputs IPC-7351 compliant footprints for a ton of of different software packages. It makes making a footprint to take like a maximum of a minute or so.
Come and check my projects at http://www.dgkelectronics.com ! I also tweet as https://twitter.com/DGKelectronics
« Reply #2 on: July 16, 2014, 02:26:34 am »
Sorry to dig up an old thread, but Seeed are now let you bulk-buy of single parts from the OPL to keep your OPL supplies topped up, or for small MFG runs.
Prices are pretty hobbyist friendly  e.g. 20xATMEGA328P-PU DIP for US$32.48 or 10x ATMEGA328P-PU 32-TQFP for $14.65.
Some of the quantities are a bit high - For example what am I going to do with 50 DC power sockets? Well at under 5c each I'll just have to build more stuff!
http://www.seeedstudio.com/depot/OPLopen-parts-library-catalog-c-136_138/?ref=side
