Just to be clear, when using this circuit, the nodes that you’re calling the “output” (because they would be, if using the bridge as a rectifier) are not the output of the circuit. The AC “inputs” of the bridge are put in series with the AC line.
But for simple on/off control, why not use a relay? And if not a mechanical relay, why not use a TRIAC or an SSR?
