You have an inverting configuration with a fixed voltage of 1.57V at the +In of each op-amp
With a gain of 1K / 20K = 0.05
![Opa2350 negative half of voltage](https://www.eevblog.com/forum/index.php?action=dlattach;topic=207072.0;attach=826197;image)
What are you expecting? Surely, you want to have some gain?
I still think you should use my previously posted circuit.
What are the voltages at RP1 and RP2? What is the max voltage you expect across these resistors?
