Author Topic: Toshiba TC58BYG0S3H BAI6 128mb nand  (Read 886 times)
Offline coolircTopic starter
  • Country: dz
« on: September 01, 2019, 07:32:18 pm »
Hello can someone tell which socket it uses and how can i take a dump of it . any programmer i can buy to be able to program the nand chip , according to the pictures i can count 67 pins on it  i don't know if the chip is an vfbga slc nand i think i did not find on the net a datasheet or something about it .
« Last Edit: September 02, 2019, 08:57:28 pm by coolirc »
Offline amyk
Re: Toshiba TC58BYS0S3H 128mb nand
« Reply #1 on: September 01, 2019, 08:40:30 pm »
That doesn't look like a valid part number. Do you have a closer and clearer picture of the IC itself?
  • Country: dz
Re: Toshiba TC58BYG0S3H 128mb nand
« Reply #2 on: September 02, 2019, 08:49:19 pm »
yes i was actually wrong the correct part is  TC58BYG0S3H BAI6
i saw it as an BYS and it was actually a BYG
« Last Edit: September 02, 2019, 08:59:32 pm by coolirc »
Offline amyk
Re: Toshiba TC58BYG0S3H BAI6 128mb nand
« Reply #3 on: September 02, 2019, 09:20:07 pm »
That's better, I've attached a datasheet and it looks like this part is still in production. It looks like reasonably standard 1.8V NAND flash but it has built-in ECC.
  • Country: dz
« Reply #4 on: September 03, 2019, 07:02:32 pm »
Thanks for your reply , i actually have missflashed a wrong version of uboot on two routers now the routers won't boot anymore and i already found a programmer that programs the nand chip and the socket for it but it's expensive , the programmer costs 1500$ and the socket costs 460$ ... , i'm not a factory i want something cheap to program two or three routers of the same chip. that's what i'm looking for.
