Author Topic: op amps  (Read 1412 times)
Offline ranganatennakoonTopic starter
  • Country: lk
op amps
« on: September 30, 2020, 03:34:27 pm »
Did anyone use "programmable" Difference Amplifier /op-Amp Subtractor IC ? (looks like PGA programmable gain amplifier) :-//
  • Country: lk
Re: op amps
« Reply #1 on: October 09, 2020, 03:45:13 am »
bump !
Online Vovk_Z
  • Country: ua
Re: op amps
« Reply #2 on: October 09, 2020, 10:15:59 am »
It seems not much people. :)
You may try to rename this topic to "Programmable opamps", if there is a possibility - possibly it may help to attract attention.
« Last Edit: October 09, 2020, 10:17:53 am by Vovk_Z »
The following users thanked this post: ranganatennakoon
Online Zero999
  • 0999
Re: op amps
« Reply #3 on: October 09, 2020, 12:42:00 pm »
There's no point in bumping a thread after less than six hours. You need to be more patient.
Are you talking about making a PGA, or buying a pre-made IC?
No, I haven't used a PGA before, but I did investigate using the PGA280, as part of a datalogger project, which didn't happen. The reason was because it works over a wide supply voltage range up to ±18V and the gain can be varied from 18 to 128, allowing the voltage to scaled both up and down, to suit an ADC.
https://www.ti.com/lit/ds/symlink/pga280.pdf
Online KT88
Re: op amps
« Reply #4 on: October 09, 2020, 10:12:31 pm »
There are resistor programmable difference amplifiers that you could get from the usual suspects...
Another category is called programmable instrumentation amplifiers or PGIAs from the same sources. They come with different digital interfaces.
Cheers
Andreas
  • Country: lk
Re: op amps
« Reply #5 on: October 09, 2020, 10:25:34 pm »
"here's no point in bumping a thread after less than six hours"
did u see see my thread ? it Posted on September 30, 2020, 03:34:27 pm. I Bumped because there was no response from anyone.
« Last Edit: October 09, 2020, 10:28:14 pm by ranganatennakoon »
Offline Phoenix
Re: op amps
« Reply #6 on: October 10, 2020, 12:32:54 am »
People are reading and responding now - and are still confused what you want. Can you give an example of the ICs in question?
The following users thanked this post: Doctorandus_P, ranganatennakoon
Online Zero999
  • 0999
Re: op amps
« Reply #7 on: October 10, 2020, 03:42:15 pm »
Sorry, I didn't look at the date!
If you don't get any replies, then perhaps it's because you haven't provided enough information. I'm still not sure of what you're asking and you haven't responded to the other points I made.
Offline Doctorandus_P
Re: op amps
« Reply #8 on: October 11, 2020, 09:58:05 pm »
I'm with Phoenix.
Post a (link to) a datasheet of the sort of IC's you are referring to.
  • Country: lk
Re: op amps
« Reply #9 on: October 12, 2020, 03:40:39 am »
I have no idea that is why I posted this thread  :-//
Offline Hiemal
Re: op amps
« Reply #10 on: October 12, 2020, 05:31:24 am »
Playing charades trying to figure out your question isn't fun.
Are you talking about this sort of chip?
https://www.ti.com/lit/ds/symlink/ina145.pdf?ts=1602480564269&ref_url=https%253A%252F%252Fwww.google.com%252F
If so it's just a differential / instrumentation amplifier with gain you "program" via two resistors. Some have just one you use.
But, again, not sure what sort of question you're trying to pose "has anyone used them before". Yeah, definitely people have. But what are you trying to find out?
