Ok, I corrected the bias on the non-inverting input, and NOW I am getting a full wave on the output. (see attached)
It also appears the gain is what I expected.
A follow up question:
Can anyone help clarify the need/purpose for caps: C1, C3 and C4? (also are there any recommended values for them?)
C1 is an AC coupling capacitor. Its value depends on the minimum frequency of interest and the input impedance (RG on your schematic).
C = 1/(2pi×F
C×R)
Where:
C is the value of C in in Farads
R is the input resistance
F
C is the lower cut-off frequency
Ideally C1 should be larger than the value given by the above formula, which returns the capacitance required to reduce the voltage of the signal to 70.7% of the original voltage.
C3 is a general power supply decoupling capacitor. It smooths out any noise on the power. If the power supply voltage increases, it charges a little, absorbing the extra energy, if the voltage decreases, it discharges slightly. You may be able to omit this if the circuit is running from a battery and there are no high current or digital circuits running off the same power supply.
C4 smooths the voltage on the potential divider formed by RG1 & RG2. The voltage on the potential divider is proportional to the supply voltage and is connected to the non-inverting input of the op-amp and is passed through to the output. Without C4, any fluctuations in the supply voltage will pass through the op-amp and appear at the output. Again if it's being run off a battery and there are no other high current or digital circuits, then you may be able to get away without it.
