Thanks for all the inputs.
I would like to stay all analog, but it has limitations.
I've been doing some research into this so I would politely show you to https://www.eevblog.com/forum/projects/voltage-controlled-sallenkey-filter-using-jfets/
Yes I saw it, and read it with great interest
BTW, where did you find your LM13700 spice model ?
I will explore all the possibilities during next weeks.
Thanks again !
Just a quick aside - currently building the photoresistor+LED-controlled Sallen/Key style filter (see attachment). It's quite elegant (even though the "voltage controlled resistors" up top aren't too pretty). The resistance of both photoresistors are about 1 megaohm when no light is on; and down to about 150 ohm with maximum intensity from the LED's. I dremeled the LED's down so they were flat, and superglued them to the photoresistor surface; hot-snotted them, painted this black, and added two layers of heatshrink insulation.
At the moment, I'm just wiring up the filter opamp (TL061CP in the middle); the voltage buffer for the voltage control is in place (cheap ass 100KHz STMicro opamp up left), as is the negative rail charge pump (a standard 7660 since I'm not gonna need more than 10-20 milliamps).
I tested the LED-photoresistor voltage control with just a simple passive RC filter, and it worked beautifully. The only important thing is to tweak the LED resistance - and thereby, the voltage control slope. That is still ongoing, but, pretty cool. And, of course, I threw in an NPN LED driver after the voltage buffer to allow for more current output than the 10 cent opamp can handle...
EDIT: Also - the photoresistor/LED combo has a bandwidth of about 100 to 200 Hz, so if you need quicker cutoff modulation, this is not a great solution. Also, it consumes more current than other solutions, but I just loved the Rube Goldberg style of it, so had to build at least one. The mounted potentiometer is an optionally connectable (single female pin) voltage controller; alternatively, you can connect an external source. The input is going to be a single RCA input - so I still gotta drill the holes for that one. But, as I said, I love the sort of quirky idea behind it.
