I want to build a simple amplifier for measuring the output noise of my PSU kit. I'm looking to measure in units of at least 5uV. I want a gain of 40, so that my lowest noise "LSB" is at least 2 real LSB on my Fluke 45 on either "fast 300mV" or "medium 3V" range.
Now, 5uV isn't incredibly low. I just pulled up the TL072 datasheet (because I have a shitload of them), and while I've always thought of it as reasonably noisy, it looks like it should work for a 0.1Hz to 1kHz* range. The noise voltage vs. frequency plot only goes down to 10Hz, but it's rising at about 18nV/rtHz/decade, so if it's 45nV/rtHz at 10Hz, I imagine it would be 63nV/rtHz at 1Hz and 81nV/rtHz at 0.1Hz. Am I correct? That translates to 14nV at 10Hz, 63nV at 1Hz, and 256nV at 0.1Hz. Multiplied by 40, that "huge" 256nV is 10uV, which is big, but well under the 100uV LSB of the meter. So, can I use it for this? Or am I missing something?
*I'll switch to the faster, but lower-resolution, HP 3437A for noise at this end of the frequency range, or use true-RMS mode.
(Of course, I know about Johnson noise, input noise current, the need to power it from a battery to eliminate external PSU noise, and the need to shield it with a thick, metal box.)
