Author Topic: Only One Component Remote Controlled latching Led Switch !  (Read 2321 times)
Offline Kedar264Topic starter
  • Country: in
  • Listen to Your Voice
« on: September 21, 2016, 09:33:58 am »
 :wtf: Yeah only one component based remote controlled switch ! :blah:
Here's The Video
https://youtu.be/qPaGx02x1cw
This Very Simple Do It Yourself Circuit Is Very Cheap And Easy To Make , It's looks really cool how it led works . The Photo diode is connected in series with an LED and placed in front of each other When a button on a remote is pressed infrared light from remote decreases photo-diode resistance and thereby LED glows and keeps on latched until you break light between photodiode and led Cool !
This Circuit Latches based on its own optical feedback , a transparant photodiode is connected in series with white led ,but there are few catches only works in low or medium light environments ,if you have any improvements please let me know ! :-+
The following users thanked this post: Srbel
Offline bobaruni
Re: Only One Component Remote Controlled latching Led Switch !
« Reply #1 on: September 21, 2016, 09:56:55 am »
That's novel :),  although I would like to see a resistor in there to limit the current.
  • Country: in
« Reply #2 on: September 21, 2016, 10:00:07 am »
Actually Photodiode itself acts as a currunt limiting ressistor here at full light its ressistance is about 1.5k ohm .
The following users thanked this post: bobaruni
Offline bobaruni
« Reply #3 on: September 21, 2016, 10:11:43 am »
Then It's even better than I thought :)
The following users thanked this post: Kedar264
Offline CM800
« Reply #4 on: September 21, 2016, 10:25:43 am »
Fun little concept actually. Pity you can't turn it off with the remote....
  • Country: in
« Reply #5 on: September 21, 2016, 10:42:41 am »
 :-/O Do you have any solution ?
