I did some characterization of a IRLZ44N via a power supply
https://www.eevblog.com/forum/testgear/this-graph-brings-tears-to-my-eye/msg2190639/#msg2190639.
Did also some curve fitting and came to the hypothesis that it should be possible to drive such a reactive component with very low gain. Here is an ongoing little experiment in which I will examine the possibilities.
First about the schematics:
It is essentially a differential 1 gain amplifier, with the reference voltage at the gate! To keep it from being a fast positive feedback, there is are a few capacitors to suppress that from happening. Given more time the ref voltage settles and Vsg become about the same.
What are the benefits of this solution compared to high gain feedback ones?
There is/should be less overshoots. There's no (relatively) large inrush current to the Mosfet gate (the gate capacitance), because this will be smoothed by a short and fast feedback loop (via R4). Resistor R12 which kind of separates the loops is therefore critical. At first I didn't have this resistor in the circuit and the outcome was rubbish.
The negatives of the circuit I will explore. It probably drops in voltage with a very sudden increase in current. Like going from 1mA to 1A. I’ll do some measurement later on.
It’s uses also quite some idle current because of the Zener diode reference voltage.
One of the attachments shows the noise while driving a DC low RPM motor at 700mA.
Feel free to discuss and comment on this experiment. (I will eventually use it as a 5 x AA battery to 5V regulator). It is with persistence on, so a 5 sec representation of the noise.
