Author Topic: One power supply into two.  (Read 2013 times)
Offline vini_iTopic starter
« on: July 22, 2016, 11:08:03 pm »
There is along story parts of which i'm not allowed to tell but there are some specific reasons why i'm doing what i'm doing.
I have a piece of industrial equipment that has an adjustable DC power supply in it (0-150VDC 0-7A). I need to turn that supply into two independent 33VDC 1A supplies. It doesn't have to be accurate but it needs to be really stable. 4mV p-p or better would be acceptable ripple but better would be well better.
What i was hoping to find is something maybe LM317 based power supply that i could feed DC into and get a lower DC out.  Can't find a thing. This would be a DC to DC supply but searching that only brings up switchers which can't meet my requirements. I could spin my own supply but characterizing it and qualifying it would take too long. I'v found a few home built and Chinese supplies with LM317 but they have the same problem as the home spun.
Where could i find an LM317 based power supply or something similar from a quality manufacturer? What could i search for other than DC to DC?
Offline Skimask
Re: One power supply into two.
« Reply #1 on: July 22, 2016, 11:13:51 pm »
You make a switcher that's noisy but gets you down to something like 40V, then go linear down to 33V.
And the LM317 only really cares about the Input->Output differential.  Doesn't matter if it's dropping 20V to 5V, or 100,020V down to 100,005V.  So, you could go 150V->120V->90V->60V->33V.  A bit on the complicated side, but simple and gets the job done.
I didn't take it apart.
I turned it on.
The only stupid question is, well, most of them...
Save a fuse...Blow an electrician.
Offline tautech
« Reply #2 on: July 22, 2016, 11:17:34 pm »
That will be straightforward enough unless you need to retain adjustability of your 170V PSU, you don't say.  :-//
LM317 datasheet:
http://www.ti.com/lit/ds/symlink/lm317.pdf
Out of office and unavailable for a few days.
« Reply #3 on: July 22, 2016, 11:18:34 pm »
The power supply is adjustable. I can turn it down to 40 or 45V, that's not the issue. I'm trying to find a prebuilt and characterized LM317 or similar power supply.
Offline tautech
« Reply #5 on: July 23, 2016, 01:16:51 am »
Would you be aware of anything like that but from a more respectable source?
Offline tautech
« Reply #6 on: July 23, 2016, 01:20:44 am »
Not at that price.
Offline Delta
« Reply #7 on: July 23, 2016, 01:25:10 am »
You also need to define "independent".  Would two liner regulators hanging off the same supply count?
« Reply #8 on: July 23, 2016, 01:34:46 am »
Not at that price.
I'd be willing to pay up to $500 for this supply from a respectable manufacturer.
Two liner regulators hanging off one supply would be perfect.
