Hi Everyone,
So I've got one of those 7351 viewers and it has the least, nominal, and most settings for pad sizes. I've baked a few boards with success, and I used stencils with a .005 thickness from oshstencils.
One of my early failures was using a pad size that was too small and it didn't have enough paste to wick up into the part when reflowing.
My question is this - I often see pcb's on eBay where the thinnest of solder is present, you can make out all the legs of parts and they look more plated with solder than coated with solder if that makes sense.
My thought is a more is better so long as you don't get bridges, but I wanted to hear what the wisdom here at eevblog is on this. More, less, what is the ideal?
