I also want to get rid of the soldering fumes without reducing solder consumption, too.
A lateral channel blower that I used to quick-start barbeque fires now has settled under my bench, with tubing intended for vacuum cleaner guiding most fumes away from my nose and out of the window.
Pictures![](http://www.primeintrag.org/dg3hda/extractor/Overview.jpg)
The main components are the blower hanging under my desk, big tubing leading out of the window, a small (not yet connected) garden hose leading to the solder iron stand und a big nozzle mounted on a desk lamp stand from scrapheap.
![](http://www.primeintrag.org/dg3hda/extractor/Detail soldering iron.jpg)
Zipties connect the garden hose to the stand. A hood is still required to direct fumes to the sucker. Was the last idea for addition, still missing a Tee to connect to the low pressure side of the blower.
![](http://www.primeintrag.org/dg3hda/extractor/Detail main nozzle.jpg)
The scrap desk lamp stand was modified with some heavy iron plates glued in the hollow foot to prevent tipping. The wastewater piping tee will be replaced by a rounded elbow for more laminar flow and smaller size. Also, I will look out for one of those "vuvuzela" horns that german soccer fans like so much as inlet nozzle. I figure it might work better than this.
![](http://www.primeintrag.org/dg3hda/extractor/Blower.jpg)
The main engine. Candidate for noise reduction!
The last hose can go outside thru the partly-open window.
Even when I intend to blow to the outside, I want to set up a filter box for activated charcoal and maybe a second HEPA stage.
