Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Projects, Designs, and Technical Stuff
On using a single Ethernet cable for communication and two activity LEDs
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: On using a single Ethernet cable for communication and two activity LEDs (Read 111 times)
squadchannel
Regular Contributor
Country:
deepl translate user
on:
Today
at 01:28:06 am »
thinking about connecting ethernet cables within an enclosure.
cable is a short length(about 60-70cm). from the RJ45 on the board to the RJ45 on the rear panel of the enclosure.
would like to have wiring for communications and wiring for LEDs on the RJ45 port, but we would like to do this with a single Ethernet cable (don't want to increase the other wiring for the LEDs).
doesn't need to be fast; 10 base is fine.
So I thought of using 2 pairs for signals and assigning(=Cat3) the other 2 pairs to each pair for link and activity LED.
Good idea? Wouldn't there be crosstalk or other problems?.
considering cables with shields used on each pair. LAPP 2170934
https://products.lappgroup.com/online-catalogue/data-communication-systems-for-ethernet-technology/industrial-ethernet-cat7/cables-for-flexible-applications/etherline-cat7-flex.html?tx_setuproducts_show%5Bguid%5D=87839343-0023-8390-ffcd-1bc9cf26bfeb&cHash=855822328aa368b03741dbc6c8d7dc22
MOD:
added diagram
Last Edit:
Today
at 02:37:12 am by squadchannel
Logged
NiHaoMike
Super Contributor
Country:
"Don't turn it on - Take it apart!"
Re: On using a single Ethernet cable for communication and two activity LEDs
Reply #1 on:
Today
at 02:07:37 am »
Add 100nF capacitors on the source end, after the current limiting resistors. It would slow down the edges a lot but would still appear instant visually.
Logged
squadchannel
Regular Contributor
Country:
Reply #2 on:
Today
at 02:43:47 am »
added a diagram.
I meant that I want to put the LEDs controlled by the PHY on the Ethernet cable.
Now that I think of it, I might die if lightning strikes.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
