I have not personally come across any ICs that meet your needs, the latest phase angle controller I've come across used an 8-pin microcontroller.
If you're not too afraid of analogue circuits (the most set and forget of them all) you could use an I2C/SPI DAC to control a 'voltage controlled dimmer' (<- a search term that should produce some of them)
