Author Topic: What programs do you use for creating technical documents???.....  (Read 25892 times)
Offline Conrad Hoffman
    • The Messy Basement
Re: What programs do you use for creating technical documents???.....
« Reply #50 on: September 01, 2021, 04:35:25 pm »
Very nice! Reminds me that I use Gnuplot for some graphs. We have wizards with Solidworks and when I need 3D I just go to them. No way could I learn that in any reasonable amount of time. For 2D I like Visual CADD better than Autocad. Drawings can be tweaked for excellent presentation, something I find more difficult with other programs. Because there are various 2D programs available for free, I think the price is a bit high, but they probably still have an "upgrade" offer to get you from Autocad or other programs, to Visual CADD. IMO, commercial use of 2D is winding down, as everybody is or has migrated to Solidworks or similar programs.
http://www.tritools.com/
http://www.gnuplot.info/
Offline PKTKS
  • Country: br
« Reply #51 on: September 01, 2021, 04:51:46 pm »
Yep very nice .. I would risk saying the capabilities of TeX are unpaired..
To complete the demo TeX can interpret embed GNUPlot code directly..
e.g. instead of plotting gnuplot onto a LaTeX terminal ( or TikZ terminal )
you can just put gnuplot inside TeX and interpret via latex.
Try
\documentclass[a4paper]{article}
\usepackage{gnuplottex}
\begin{document}
\begin{figure}%
  \centering%
   \begin{gnuplot}[terminal=epslatex, terminaloptions=color]
  FIT_LIMIT = 1e-25
set datafile missing 'NaN'
set samples 1e3
set isosamples 1e2
set   title font "Arial,14,bold,iso8859"   enhanced
set  xlabel font "Arial,12,medium,iso8859" enhanced
set  ylabel font "Arial,12,medium,iso8859" enhanced
set x2label font "Arial,12,medium,iso8859" enhanced
set y2label font "Arial,12,medium,iso8859" enhanced
set   label font "Arial,12,medium,iso8859" enhanced at 1,1
set angles radians
set nopolar
set zeroaxis lw 2 lt 0
set style function lines
set nokey
set tics out
set border front ls 3 lw 1 lt 8
set grid back    xtics   ytics nox2tics  y2tics ls 7 lw 0.100, ls 15 lw 0.100
set grid back   mxtics  mytics  mx2tics my2tics ls 8 lw 0.100, ls 15 lw 0.100
set arrow filled ls 7 from 1,1 to 1,1
show tics
show mxtics
show mx2tics
show mytics
show my2tics
show label
show border
show title
            set xr [-5:5]
            set yr [-1:1]
            set xlabel '$x$'
            set ylabel '$y$'
            plot sin(x) w l lc 1 t '$\sin(x)$',\
              cos(x) w l lc 2 t '$\cos(x)$',\
              tan(x) w l lc 3 t '$\tan(x)$',\
              tanh(x) w l lc 4 t '$\tanh(x)$'
        \end{gnuplot}
   \caption{This is a simple example using the latex-terminal.}%
   \label{pic:latex}%
\end{figure}%
\end{document}
absolute worth saving in generating complex documentation..
GNUPlot and  other packages can not do direct inline math like TeX.
(although some tricks allow embedding stuff results are far from good)
Paul
« Last Edit: September 01, 2021, 04:59:53 pm by PKTKS »
Offline PKTKS
  • Country: br
« Reply #52 on: September 01, 2021, 04:58:39 pm »
Here another most interesting gem about TeX..
The Circuit and Chemical symbols packages allows arbitrary high quality circuit documentation almost effortless.. all your created library can be reused as well
Try:
\documentclass{article}
\usepackage[utf8]{inputenc}
\usepackage[english]{babel}
\usepackage{circuitikz}
\begin{document}
\begin{center}
\begin{circuitikz} \draw
(0,0) to[ variable cute inductor ] (2,0);
\end{circuitikz}
\end{center}
\begin{center}
\begin{circuitikz}[american voltages]
\draw
  (0,0) to [short, *-] (6,0)
  to [V, l_=$\mathrm{j}{\omega}_m \underline{\psi}^s_R$] (6,2)
  to [R, l_=$R_R$] (6,4)
  to [short, i_=$\underline{i}^s_R$] (5,4)
  (0,0) to [open, v^>=$\underline{u}^s_s$] (0,4)
  to [short, *- ,i=$\underline{i}^s_s$] (1,4)
  to [R, l=$R_s$] (3,4)
  to [L, l=$L_{\sigma}$] (5,4)
  to [short, i_=$\underline{i}^s_M$] (5,3)
  to [L, l_=$L_M$] (5,0);
  \end{circuitikz}
\end{center}
\end{document}
I like this one very much among TeX packages
Any arbitrary high quality format can be used as terminal output
Paul
Offline SiliconWizard
« Reply #53 on: September 01, 2021, 05:24:55 pm »
Once you know LaTeX all the rest is just noise.
Oh, I agree. But doing everything in LaTeX is not easy though when you work in a company, because anyone else potentially having to edit your documents has to know LaTeX as well... this is particularly problematic for manuals - for which marketing departments often want to have the final say, be able to edit appearance, etc. Try having a marketing person use LaTeX...  ;D
The following users thanked this post: rsjsouza, tooki
Offline Bassman59
  • Yes, I do this for a living
« Reply #54 on: September 01, 2021, 05:26:13 pm »
Come back Ventura Publisher all is forgiven - I never forgave Corel for ditching it.
D.
Come back Lotus Manuscript!!!
Offline PKTKS
  • Country: br
« Reply #55 on: September 01, 2021, 05:35:12 pm »
Yep YOU DO HAVE A POINT HERE..  ::)
TeX learning curve is  steep ..
but the capabilities are far more strong.
Best of all also free of charge as in OSS
Total final cost must be a weight factor.
Nevertheless PostScript is far more difficult to learn than TeX
Paul
Offline emece67
« Reply #56 on: September 01, 2021, 06:26:00 pm »
« Last Edit: August 19, 2022, 04:39:58 pm by emece67 »
Offline TheUnnamedNewbie
  • mmwave RFIC/antenna designer
« Reply #57 on: September 02, 2021, 11:37:19 am »
I have to use Latex a lot, and similarly to linux, I never really understood all the hype.
I feel like both of them 'seem' better because you are more forced to do things 'the right way' or you are forced to learn the insides because it just has that steep a learning curve.
I think if people spent as much time learning to use MS Word, InDesign, or similar tools as they do learning LaTeX, it wouldn't be anywhere near as popular as it is.
Myself, I use InDesign a lot. Heck, I even cloned my place-of-work's powerpoint template into InDesign so I can use InDesign for presentations too. My graphics are all made in Illustrator. Graphs I have a workflow of standard-plot-scripts that I use to produce the raw graph in Matlab, and then do some postprocessing (sometimes) in Illustrator too. What I love about the Illustrator+indesign flow is the use of multiple layers in Illustrator, which I can toggle in Indesign. Makes it very nice to 'add' traces to graphs across a number of slides, or 'build up' a figure gradually.
Papers I find myself being forced to use LaTeX often simply because the organizers only offer a (mandatory) LaTeX template, sometimes even requireing you to send in the plaintext latex file along with a PDF for their internal typesetting flow.
« Last Edit: September 02, 2021, 11:39:14 am by TheUnnamedNewbie »
The best part about magic is when it stops being magic and becomes science instead
"There was no road, but the people walked on it, and the road came to be, and the people followed it, for the road took the path of least resistance"
