Author Topic: OCXO Stable Reference and Control Voltages?  (Read 29946 times)
Offline FlyingHackerTopic starter
  • You're Doing it Wrong
« on: March 01, 2016, 06:54:19 am »
What do you folks think is best practice for the reference and control voltages for fine tuning an OCXO? Is a passive divider network off VCC sufficient, or should I be looking at a reference IC, and then a passive divider off the reference? Or something else entirely?
The oscillator itself is quite stable, but if the voltages drift (relative to one another) then any tuning is not so useful.
I'd like to maximize long term accuracy, and have to recal only a couple times a year.
The OCXO is this guy:
http://www.ctscorp.com/wp-content/uploads/2015/12/OCXO196.pdf
Thanks in advance.
--73
Offline AdamHi
Re: OCXO Stable Reference and Control Voltages?
« Reply #1 on: March 01, 2016, 04:14:06 pm »
I've always assumed that you'd want to divide off a stable separate voltage source - but you got me thinking that maybe i'm wrong! If you find the answer elsewhere, please keep this post updated.
BTW - where are you sourcing this OCXO? eBay?
--adam
Offline grumpydoc
« Reply #2 on: March 01, 2016, 04:59:19 pm »
Depends of the accuracy that you need (or can "calibrate" to).
The tuning range is 7x10-7, therefore 5% change in your VFC will be 3.5x10-8 (35ppb).
Only if you can measure to better than that is worring about VFC to better than 5% going to do you any good.
Offline NivagSwerdna
« Reply #3 on: March 01, 2016, 05:03:48 pm »
Maybe you could watch
That's the design I plan to use if I ever get around to adding an OCXO to my Racal Dana 1999.
Offline suicidaleggroll
« Reply #4 on: March 01, 2016, 05:07:57 pm »
OCXOs typically provide their own reference designed for this purpose.  The pdf you linked shows it's on pin 2.  Use that reference with a voltage divider or similar, and feed the control voltage back into pin 1.
« Reply #5 on: March 01, 2016, 05:25:25 pm »
The hint is in the datasheet for the part. There's an option - option R - to get this OCXO with a reference voltage output. If they are going to bother to make a part that provides a reference voltage output I'd take that as a hint that it might be a good idea. If you do the calculations on the tuning  range (+/- 0.7ppm) versus the Allan deviation (0.01 ppb @ 1.0 sec) you'll get an idea of the voltage stability needed - 1 part in 140,000 (~7 ppm) would introduce an error equivalent to the Allan deviation.
Moreover, I'd hope that they arranged the drift of the vref output to follow the oscillator drift (with respect to tempco, power etc) in a compensatory fashion - making it a more attractive option than providing your own reference.
« Reply #6 on: March 01, 2016, 06:54:43 pm »
Ahhhhh! I misunderstood how it worked. I thought I was supposed to *apply* 4.0V to that VRef pin, and then apply the correction voltage to the VC pin. This makes much more sense...
Hopefully I did not damage the unit, but it doesn't look like I did on the scope (and in comparison to the other OCXO unit).
Thanks.
--73
Online Vgkid
« Reply #7 on: March 01, 2016, 07:19:10 pm »
The internal ocxo voltage is generally rather stable. I have a few that are of similiar size to your CTS unit.
If you want, I can power one up(NOT A CTS, a C-MAC), and record its stability for you. Will not be the greatest, as will have only been running for a few hours before measure>.
« Reply #8 on: March 01, 2016, 09:15:19 pm »
I appreciate the offer. I am trying to learn about these things. You are referring to recording the change in voltage of the Vref over time? I could do that with my bench meter as well.
Or are you talking about recording the frequency drift? I don't believe I personally have any tools to do that. The bench meter (which does logging) can only go to about 300kHZ (and does not have an external clock), and my frequency counters cannot record things (and they are not even oven controlled, which is why I am messing with these OCXOs.)
--73
« Reply #9 on: March 01, 2016, 10:23:49 pm »
Yes but the OP didn't state they had option R.  In the absence of option R then the solution might depend on your budget...
.. if you are not price sensitive then a voltage ref ic would work (that's what I'm planning to do) (I think that's what was done in the video I referenced)
Online Vgkid
« Reply #10 on: March 01, 2016, 11:15:17 pm »
@ Flying hacker: correct. Still will post anyway.
if you want to seethe long term stability check my 'Allen Deviation' thread in the beginners section.
Somthing is not going good with my setup, if you look at the aldev graphs.
@ NivagSwerdna: I agree. A rather decent 5v ref chip will work out good.
« Reply #11 on: March 02, 2016, 01:40:20 am »
Yes, as the OP I do indeed have option R. So that will work great. Thanks. I misunderstood the application.
Vgkid: I will check that thread. Thanks.
--73
Offline uncle_bob
« Reply #12 on: March 02, 2016, 02:44:17 am »
Thanks in advance.
Hi
If you are looking at that specific CTS OCXO on eBay right now ... beware ... the current drop is defective. They have an internal spurious oscillation. The suspicion is that they sent them to the dump as scrap and they wound up on eBay instead.
Bob
« Reply #13 on: March 02, 2016, 04:41:40 am »
Thanks in advance.
Hi
Hmm. The two I got seem pretty stable. with 20MHz BW limit it looks like a perfect sine. At 300MHz it has a little distortion, but rock solid. How would one identify this problem? I don't have a spectrum analyzer/FFT. My scopes are old school Tek gear.
--73
Offline Theboel
  • Country: id
« Reply #14 on: March 02, 2016, 05:08:22 am »
Thanks in advance.
Hi
Bob
Can You more detail about your information Sir. I need a few of this ocxo.
Online Vgkid
« Reply #15 on: March 02, 2016, 05:18:32 am »
If you read through it and find something that interests you, I can post the image of the graph(you most likely don't have TimeLab)or anything else that you want, as I still have the files, or atleast I could download them.
-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_
In some documents they suggest using trimmers with tempco's better than 50PPM, but that can get expensive, just use a string of nice resistors, with a pot for trimming.
« Reply #16 on: March 02, 2016, 05:31:32 am »
TimeLab looks interesting. Do you then have a TimePod to connect to? This is all stuff beyond my hobby budget for now (and I need a Spectrum Analyzer first anyway).
I checked the thread. It may be a little too academic for my uses (read that as, I don't have the time to dedicate to figuring most of it out :scared:) It is interesting to read, though. Thanks.
--73
« Reply #17 on: March 02, 2016, 01:43:32 pm »
Yes, but that's kind of irrelevant in the context of the availability of the option suggesting that such a thing might be useful in conjunction with this part.
Offline uncle_bob
« Reply #18 on: March 02, 2016, 11:04:44 pm »
Thanks in advance.
Hi
Bob
Hi
Multiple people who have purchased these OCXO's on eBay over the last few weeks have all reported a spurious signal on the output at a level high enough to make the useless for their needs. The signal is broadband and show up as a series of spurs all at about -100 dbc spaced at a uniform interval of 40 to 80 Hz (depending on the exact unit tested).
Bob
« Reply #19 on: March 02, 2016, 11:15:15 pm »
Thanks. I don't have a spectrum analyzer, but these look solid on a 300MHz scope. I will slow the scope down and see if I see anything. Does this look like AM modulation, what?
They also seem to work fine as an input to at least two frequency counters. I ordered mine about a month ago. They were bought from a seller selling them in pairs.
--73
« Reply #20 on: March 02, 2016, 11:38:41 pm »
I can trigger off some kind of harmonic at around 333 Hz. Not sure what that is.
--73
Offline uncle_bob
« Reply #21 on: March 02, 2016, 11:53:09 pm »
Hi
It shows up as phase modulation. With a *lot* of care, you can catch it on a scope. You sort of need to know the modulation frequency first and then adjust the scope's trigger to duplicate it.
Bob
Offline uncle_bob
« Reply #22 on: March 02, 2016, 11:54:45 pm »
Hi
You may be triggering off of a spur that is at 333/N where N could be 4,5,6,7 ... who knows.
Bob
« Reply #23 on: March 03, 2016, 02:17:23 am »
Yeah, I don't think I would be able to tell if these are affected without a spectrum analyzer.
Anyone have one of the bad ones on a scope?
--73
Offline uncle_bob
« Reply #24 on: March 03, 2016, 02:40:24 am »
Hi
If you bought them in the last month or so, it's just about certain they are out of the defective lot. They show up in singes, pairs, and trays of 40 or so. There are a variety of seller names. I doubt there are very many real sellers behind all those names.
Bob
