Author Topic: Custom 2.5-inch IDE SSD Assembly and Testing  (Read 552 times)
Offline TraderTopic starter
« on: January 19, 2023, 06:16:04 am »
This guy projected, make, and programmed an SSD.
« Last Edit: January 19, 2023, 07:12:43 am by Trader »
Online coromonadalix
Re: Custom 2.5-inch IDE SSD Assembly and Testing
« Reply #1 on: January 19, 2023, 11:10:51 am »
And ?
Sure it's doable, kudos for that
But the read and writes speeds are  slooooooow
Better buying already made products
Since it is an pata  interface, you have DOM  (disk on module devices)  or ide SSD,  but you need the right model, since some os  aren't managing the trim functionality
« Last Edit: January 19, 2023, 11:13:21 am by coromonadalix »
« Reply #2 on: January 19, 2023, 03:48:15 pm »
I guess this guy is on track to someday do a 10Tb SSD on Gen 5 PCIe x4
