I have to build a PIC µC based "multimeter" at school. The sensor part has to be 1x1 in and is connected to 5 I/O pins of the controller and two of them can be used with the integrated 10bit adc. The supply voltage is 5V so i can not really use more than that.
So I am looking for interesting sensors or other stuff i could measure. I was thinking about a coax cable length meter that applies a fast rising edge to a open ended coax and then measures the reflection but the PIC is clocked at 4MHz so one instruction cycle is 1µs which means I can not measure short enough times to do that. Of course I could jut make a voltmeter, currentmeter, thermometer or something like that, but I would like to do something more challenging so I am looking for ideas. Keep in mind I only have 1 by 1 inch of double sided PCB .
